With a little over 22, 500 on the clock, I changed the fluid in my 5600 today. The problem I was having was after coming to a stop, idling in nuetral for a minute or two, I was having to "double-tap" (against the syncros)the shifter to get it into first or second. If I just tried to put it into gear without taping it, it would not go in. After the fluid change, it seems smoother, but not great. I saved the fluid as I want to get it analyzed and it had a grey-milky look under the surface. Meaning, it would look like normal fluid on the surface, but stir it and it has a marbled appearance. It does not seem to be separating out as if it is moisture.
I don't tow much, but I do a lot of city driving. It does not grind shifting from 1-2. It feels smooth once moving.
Oh yeah, I put the Mopar fluid in it in case I have issues with this thing. I now have records that the factory recommended stuff is in there.
