I have a 2000 3500 five speed. It has about 125,000 miles and the injector pump and lift pump were replaced at about 119,500. I don't drive the truck much and yesterday I tried to use it after it had set (outside) for about three weeks. The last use was a 250 mile road trip empty. It has close to a full tank of fuel. I brought the truck from my son last summer. He had bought it from a friend so we know some of its history. I don't have any extra gauges on it yet.
It was 60 degrees here yesterday but it has been in the teens just a few days ago.
Yesterday when I went to start the truck I had problems.
After waiting for the wait to start light to go out I cranked the truck and as usual it started right off. However it only ran a few seconds then died. I turned it off then back on again and waited for the wait to start light to go off. The truck just cranked and never hit a lick. I repeated this process several times, sometimes cycling the heaters twice. The truck was still cranking over very well but did not even try to start. I gave up and ran my errand in my Magnum.
Several hours later I tried again with no luck. However when I was just about to give up and hook up the block heater I gave it full throttle while cranking and it fired right up and ran fine, so smoke, ran like nothing had happened.
I looked in the owners manual and there was no circumstance described in which you where to give it any throttle when starting.
I have had two other incidences when it has been cool and the truck has died after starting. While a little hard to start these times the truck has started after cranking a few times.
Any idea what is going on here?
Thanks,
Bill Lamb
Thanks,
Bill Lamb
