Darkbloodmon
That will take a fair amount of duration to get to with near stock sticks. Likely if you’re after low end power you will hit the torque limit first.
Also, the turbo will be a limiting factor if your looking for a towing setup and even not towing 490 would be quite hot on a HE341.
A good all around tune, without out really pushing duration, rail pressure, or timing would likely net you 400/850 for street and 350/800 for towing with those injectors and turbo.
I can live with that, not trying to brake things, just rip foundations out. The 341 screams already near the factory fuel cut, If I need a bigger margin for reliable operation I'll just bump up to a 351. Any drive line concerns for factory components near 800 ft lb?
