Need advice on a fix for my starter bolts on '96 Ram 2500 4wd Cummins w/5 speed--they keep loosening. The top bolt seems to have lost some of its thread and actually works loose and falls out.
I discovered problem 3 weeks ago, replaced top bolt, tightened all to seemingly snug position. Yesterday, the starter had a strange sound and I found the top bolt again missing, with the bottom ones loosened a turn or so.
I had starter replaced with a rebuilt 3 yrs. ago. Perhaps there was some cross-threading on the top bolt?
After replacing the missing bolt, and retightening all, I decided to check the threads and removed all three. The threads on all 3 contained a lot of metal--probably aluminum.
I've cleaned the threads and reinstalled the bolts, but I think the loosening will continue--especially on the top bolt, which tightens with less authority than the other 2.
What procedures can you recommend to cure the problem?
Thanks, in advance for your assistance.
DrJC
From Michigan, in LA, leaving tomorrow for home
DrJC
