There is a older couple that I am friends with that have a 97 Cab & Chassis , with a flat bed and a five speed . The last week or so sometimes when you are trying to start it it will crank over but will not start . When you let off the key and try again it still will not start but if you turn the key to the off position then try to start it again it will start . What is causing that ????? Well today they call me and told me that when they tried to start the truck for the first time this morning the starter stayed engaged and would not un- engaged when they turn the key off . So they left the key in the on position and it kept running (engine and starter)and smoke started coming out from under the hood and it finally shut it self down and with some help from another friend they figured out they burn up the lift coil , shut off valve , shut off solenoid , or what ever it is call'd . They got a new lift coil from the Dodge Dealer and did they ever get ~ well I have to be "Politically Correct" here now ~ it cost them four hundred and fifty dollars. After they put the lift coil on all the starter would do was just click so they call'd me . Well I went to look at the truck and I kept trying to start the truck and finally got the starter to work by working the key switch back and forth from the start to run position but sometimes it still will not start and run until you put the key switch in the off position then hit it again. I also got the starter to lock up again and I could not get the truck to shut off but I did jump out real fast and disconnected the lift coil to shut it down . Why is the starter hanging up ??????? I did swap the relays around ( in the black box on the driver side fender well ) but that didn't help anything . Also when the truck is running now (and the starter is not lock'd up) that lift coil gets real hot , is that normal . I need some help here cause I don't know nutten about a Sec. Gen.
