Starter of Dodge pick up fit where I had an acdelco 28mt?
Inquiring engine minds
Sticky wheelwright touching caliper
HI guys, do any of you have any idea if a standard gear reduced starter of a dodger pickup with 5.9 work on my tool truck which had acdelco 28mt?
Thanx
If you had a MT28 starter. That means you have a SAE #3 engine adapter most likely. I dought the dodge starter will work. The nose on the dodge starter is small than the MT28. They both have the same number of bolts. But the sizes are different. The MT28 runs larger diameter bolts. I am pretty sure the MT28 has a larger bolt pattern than the dodge.
Yes you are correct. I have to stay in the lines of the delco line all the way to mt49. Thank you for your reply sir!
