Details here: TDR Privileges
Know a couple guys that had starter problems they called Larry B's and within a 1/2 hour had in contcts in and starts great it looks easy to replace the contacts.
Order Larry B's super contacts & your problems will be cured until the brushes just flat wear out. The contacts are easy to replace & they & a new plunger are under $40. http://www.fostertruck.com/dodge/default.htm
Exact same things happened to both my dads and my truck. The contacts were bad in both starters. We got our contact/plunger kits from
www.mrbobsdistributing.com. The kits he has are the same size contacts as stock. LarryB's are a lot bigger. Either way, one of these kits should fix your problem.
