I got in the truck yesterday and it started but cranked very slow. I pulled both batteries and had them tested. Both failed so I replaced them. Still had same problem so I pulled starter and had it tested. It also failed so I replaced that too. After I replaced the starter there was a click then nothing at all. I took new starter back off truck and had it tested and it passed. Put starter back on truck and found blown fuse F2. I replaced fuse and tried again. Fuse blew instantly. Replaced fuse again, traced start wire up to connector by pdc and that looked fine. Pulled start wire off of starter and turned key to start. There is 12 volts on start wire when key is in start position and fuse does not blow when start wire is not attached to starter. TIA for any help!
