I have had an intermiten starter problem over the last week. It won't engage the starter. It seemed that it engaged if you jammed it a little harder into park, so I thought it was the neutral saftey switch. It was so bad Sat. that I had to do something, so I changed the switch. It still did not start. The relay was clicking so It was not that. As a last resort, I rapped on the solenoid with hammer and kicked off. It has started for the last two days. I realized that I am on borrowed time until it quits completely. I hate to buy a new starter if the sol is only bad. Can you buy just the sol or is there a good place to buy a starter outright and fix mine for a back up. I am going to have two CTD on the road and would not mined having a spare.
Mark Faught, 92 ext cab service truck and a 84 crew cab one ton dually with a 91 cummins and NV 4500.
