Archived Starter relay location
Archived Help! '93 W250
Archived fuse box fried
06 won't start. need the location of the starter relay. truck has the totaly indagated power distribution modal.
Not sure of 06, but on an 03 the starter relay is in the power distribution center (where fuses are in the engine compartment).
Note: If your batteries are weak, I think it will not even try to start.
Thank you for your reply. my 06 has the TIPM in place of the PDC. Eaighter the starter relay has been relocated or replace by solid state componet in the TIPM.
Found it Page 8W-91-46. Under the hydro formed upper finder support, behind the TIPM. All tested good. must have been dirty connection, because now it starts.
