Details here: TDR Privileges
Does anyone have any advise about starting a CTD that has been setting for 30+ days? I am pretty sure I put power service in before it was parked. But I am not positive. TIA.
Pop the PDC cover and pull the fuel system relay. That kills the power to the VP. (You will turn on your check engine light, but it will go away in a couple starts. )
I then crank her for 20-second intervals. (Maybe about 4 sets?)
That will prime the oil pump and send lube all through the motor without allowing it to start.
I also do this after turbo changes to fill the turbo cartridges.
Cranking too long is very hard on the starter. On the other hand, I have torn down engines that had sat fro a couple of years and found the bearing journals were still filled with oil. bottom line is I would just start it and drive away.
