I would suggest putting a volt meter on the starter lug while having someone turn the key to the start position, if the battery's are going bad they can read full voltage until you put a load on it then drop to 0 volts, if so also check it at the battries, if it's normal voltage in the start position then your looking at a cable or bad connection
Since you stated its been starting slow lately I don't suspect a relay or fusible link since that should cause an instant problem, though I have not dealt with 1st gens much so I'm Just going offs electrical knowledge
