97 truck when parked uphill overnight, starts and dies. seems fuel in p7100 is what is startind on then loses prime... doesnt seem to lose it completely cuz dont have to bleed or crank THAT long to run again... double checked fuel lines from tank to motor with psi applied to tank... no leaks... checked fuel pump psi found low replaced it and the inlet hose... replced fuel filter... replaced overflow on p7100... was fixed for about 3 months then started doing it again... replaced overflow with TORK TEChnologies valve and replaced fuel cap thinking maybe a vacuum was happening, still does same thing. starts fine on level ground or backed into driveway. does not have the problem any other time just over night. truck runs great also. what am i missing?
