Now that the weather has changed my 01 CTD is having trouble starting. When the temp get to be 60 degrees or warmer outside my truck cranks for a while before it finally starts up. In the morning when i start it, it cranks right up but after i drive it a while then try to crank it up agian it cranks along time before it starts. In cold weather it starts fine all the time. I have already replaced the lift pump. I have a carter 8 psi pusher pump and my fuel pressure sits abot 26psi at idle sometime right after I start it it sits at 24psi. Does anybody know What could be wrong?
