more information please. If there is an air leak in the rubber lines, or one of the connections that can happen. try hooking a compressor with a nozzle attachment to the rubber fuel supply hose and clamping off the return. If there is an air leak you will see bubbles. Only use 10-15psi. Either take the starter off or the tire/mud guard for access. The fuel system write up might have a diagnosis for that problem. Try and explain it as best as possible first so you don't waste as much time as I did.
