Engine/Transmission (1994 - 1998) starwheel adj.
2nd Gen Non-Engine/Transmission Jiggled something
The starwheel on my truck is located so far foward that you can't get a screw driver on it to turn it. Does this mean it is already turned up or do I need to pull the cover and adjust the starwheel. I installed a TST #5 plate and I really like the way it has woke my truck up, but it still seems a little sluggish on the low-end and I'm not seeing much smoke either. I was hoping the starwheel adjustment would help some. Thanks
J Pearson
afc housing
Has the afc housing been slid all the way forward in the slots on the housing? If that has been done, there is a screw on the backside of the afc housing turn that in a couple of turns and that should bring pre-boost fuel alot sooner, and get you some black smoke, and better acceleration. Oo.
