Engine/Transmission (1998.5 - 2002) STD vs HO Compression Ratio
2nd Gen Non-Engine/Transmission I need help- The $21000.00 question
Engine/Transmission (1998.5 - 2002) Low speed noist
Is there a difference with the compression ratio between these two 24v engines? If so, would it be worth swapping from a std to an ho??? I'm thinking probably not, but know a guy who wants to... With all the mads available for these, would there even be any difference when you got to the 600-700hp range??
