Joe, I'm in the same position as powrwagon and JGheen. I don't understand what I am seeing in relation to the usual description of these lines. Perhaps the 98's are slightly different. I have ordered the marine cables as preventative maintenance, but I can't see where they would go as normally described. Looking from below, it seems that the 2 steel pipes appear from behind the fuel filter. These are then connected with quick release connectors to high pressure slightly flexible lines with an outer rubber sleeve for protection. These are about 18 inches long, and are swaged into the steel pipes from the tank. The existing setup seems too good to replace with flexibles and a couple of clips. The usual description is of flexibles behind the fuel filter, getting hot beside the engine and then leaking. Are the 98's different, or am I being more dense than usual?? Nick.
