Hey Guys,
Just got done putting on new tie rods as well as Lukes Links on the draglink ends. Planned on putting Lukes Links on the main tie rods as well but they were wore past that point so I put complete new ones on. ANYWAY,,,,,improved my sloppy steering immensly!! I have the DSS kit, Lukes Link and new bushing on the original trackbar, Lukes Links on both ends of draglink, new tie outer tie rods, original ball joint which are tight.
I did notice as I was putting draglink back on pitman arm that there is a small amount of play in the steering gearbox. Now by this I mean as you turn the steering shaft by hand, it travels a ways before the pitman arm will rotate, I have no lateral slop at all, that I can tell anyway, again what I am referring to is actual play in gears themselves not the bearings.
Question: will adjusting the gearbox with the adjustment nut tighten this up?? Will the other adjustment where you tighten the other deal help??
If not can someone reccomend a reman or new box that wont break the bank? This vehicle is used 50% hiway, 50% gravel pulling flatbeds and/or horsetrailer with 4 horses and gear, I rally dont want a fancy offroad setup ig I dont need one,
Thanks
ps My truck is a 99 3/4t 4wd CTD 5 speed EDGE EZ 4 in exhaust, truck bought new by me, has 170,000 miles on it and I love it to death, if it was a women I would... ... ... ... well you know... ... ... ... !!!!!!!
Thanks
