Engine/Transmission (1998.5 - 2002) Steering box input shaft play.
2nd Gen Non-Engine/Transmission block heater-gauges
Engine/Transmission (1998.5 - 2002) Lift pump failing?
I have play in my input shaft of the gear box but not the out put shaft. I just did the TSB on the adjustment for it. It helped a little bit with also changing one tierod end of the pitman arm. Does the input play matter. It had radial play.
Also my steering column moves side ways back and forth a quiet a bit where it comes out of the fire wall. Seems odd. Is this normal?
