It depends if you have the small gear box or the large gear box. The sector shaft nuts are a different size between the two and the flange on the brace that the bearing bolts to is welded in different locations for the different boxes. You can tell which gear box you have by the number of bolts on the end of the box. The small box has four bolts and the large box has six bolts. Hope this helps.
