2nd Gen Non-Engine/Transmission steering brace
Can someone kindly provide the contact info for Darins steering brace. On my 96 the pitman arm shaft is loose and the box has a clunk. while turning the front end had a crack /pop sound . bast i can tell its from the box everything else is tight (Lukes link) will darins brace help???? THANKS
I have been talking to Darin about becoming a dealer and he has been one of the nicest guys to work with. Mine should be coming in soon along w/ a DT track bar and am pretty excited. My current track bar only took about 5k to go out.
I put one on my 96 a while ago - GREAT PRODUCT!!
I had a leak at the pitman shaft - but some bonehead decided to put another seal on the shaft instead of replacing it correctly. That means to get the seal out you have to disassemble the steering box. I didn't want to do that if possible.
I put on the DSS and w/o movement of the pitman shaft - no more leak!!!!
YES! - also handles MUCH BETTER!!!!
Dan
