I recently had the steering gear box replaced on my '92, and it's now making a noticable clunk when I turn the wheel a certain amount. It doesn't matter which direction I turn the wheel, but it's definitely louder turning the wheel to the left.
I had my girlfriend turn the wheel while I got on the ground and watched, and it looks like the gear box itself moves a tiny bit when it clunks. For example, as if something is binding up and then releasing once the steering wheel is turned past a certain point.
I did just install a Borgeson steering shaft and new rag joint, but it was making the clunk before I installed it. Installing the shaft didn't make any difference in the clunking, better or worse.
I'm still at work, but when I get home I'm going to check the gear box mounting bolts to see if they're loose (I think someone mentioned something about this in another thread in the past day or so). Does anyone know of anything else I might check?
Thanks,
Mike
Thanks,
Mike
