gpintler
It is a small thing but it matters to me.
when you sit in my truck, the steering column looks to be mounted incorrectly.
1] all 4 bolts that support the column are tight
2] the plastic cover over the column appears to be on straight. turn signal shaft, gear shifter and hazard button all line up in the plastics correctly.
I want to install the gauge pod on the column but when I do I can not see the mileage.
thank you
thank you
