Steering Column Locked
Cruise control hasnt worked full time since November.
Anyone heard of or used this on their A/C high pressure line?
Went to start my 2006 6 speed manual truck and could not turn the key. After much jiggling of the key it finally turned. I'm guessing that the switch is shot since you can take the key out with the truck running. My only concern is that it was locked tight and I am not sure just a bad switch could cause that. If it is the switch how much trouble is it to change.
Thanks
Jeff
If it is the ignition switch, it's about $50 and 30 minutes worth of trouble. If it's the key cylinder, it's about $80 and 20 minutes of trouble, plus the time it takes to rekey the new cylinder to your old key before you install it. The prices are rough prices based on auto parts stores and Internet vendors. If you go to the dealer the prices are significantly higher.
