Steering Column Noises
Rotated Tires Yesturday on Dually-Man am I Impressed!!!
Cab light install--not working
My 97 has clunking noises coming from the steering column that now feel like the steering wheel will fall off. Any suggestions.
97 2500 extra cab B5. 9 152k and strong
Sometimes the grease in the sliding shaft will work its way out causing the clunking or popping. There was a TDR suggestion a couple of issues back that recommended squeezing the base of the rubber boot on the shaft to force the grease back into the slide area. I believe I saw another post where someone slid the boot down and lubed the shaft.
