Bought truck used 10 years ago, already had dual steering damper installed, not sure of the brand, but the hardware looks like a Skyjacker setup. Fast forward 10 years and 120k miles, trying to tighten up the front end, thought I would replace the dampers along with the ball joints and steering box that I just replaced. Did a bunch of measurement and finally bought Bilstein dampers that had the same measurements as what was already on the truck. Problem is, the Bilstein dampers have different eye diameters, and will no way fit on the current hardware. As you can imagine, rust and age have taken their toll. I have searched for hours, I cannot locate any special hardware for the Bilstein dampers. I suspect they will fit the stock mountings, but since I already have a dual setup this is certainly not the case. Would it be unreasonable to replace the current hardware with some quality Grade 8 bolts, washers and nuts?
