2nd Gen Non-Engine/Transmission Steering-Dropped pitman arm
Engine/Transmission (1998.5 - 2002) Losing power .....
Hey guys-
I've got the skyjacker 4. 5 inch lift. The pitman arm on my truck is stock and it def. needs to be dropped lower. Skyjacker sells a 2 inch dropped arm and a 4. 5 inch dropped arm. I have a DT track bar. Anyone with the 4. 5 inch lift have an opinion on the skyjacker dropped pitman arm or maybe another companies dropped pitman arm?
Thanks
erik
Whatever arm you get you should also drop the frame end of the track bar the same amount to maintain the correct steering geometry, the drag link and the track bar need to stay parallel to prevent bumpsteer...
Jared
