DVolk said:
The reason is not because of cross over steering gear , you need to
check closer its not a cross over read any 4x4 mag to see the diffrence
Well its a 4X4 truck as it has leaf springs, and the pitman arm is swinging side, not front to back like stock, so its crossover steering.
My 4X4 that is stock would break the plate between the steering box and frame, not the frame. The plate that is not on this 4X4. I have two trucks, one with each setup. I even have a 75 dodge that my crossover setup was on, and it cracked just like his did, and it wasn't from the 20 years previous stock setup that cracked the frame, it was from the 2years of wheeling with crossover steering. The steering gear box when setup on the frame for crossover really twists the frame as its pushing side to side, not front to back. As for reading 4X4 mags, I've got years of Peterson's laying all over this house.
DVolk said:
its a flaw design and according to sevral Dodge dealers this has happended
on both 2wd or 4wd vehicles with stock tires and wheels or big mud luggers
I'll agree with this to an extent. Not necessarily a flaw, just not built heavy enough for aggressive terrain. I only had problems with my stock setup when I hit something hard, like a large hole offroad. On the street, normal driving, no problem. Just when I abused the equipment.
DVolk said:
but then yet ive seen lifted trucks with 44's and 350K with out ever been touched or needed fixed or braceed , go figure
Even since I put the updated plate on my stock truck, I've had no more problems. Dodge changed the plate for a stock 4x4 many times. Then again I've quit wheeling my 93, it pulls the trailer, and is my nice truck. I won't comment on 2wd as I've never owned one or had to fix one.
So far, since I upgraded the frame on my 90, even with crossover I have had no problems with it either. I do remember very distinctly when I had a friend steer my truck with crossover, the stock frame(without support) would flex when the steering box would meet resistance.
Michael
