2nd Gen Non-Engine/Transmission Steering linkage conversion on 95
2nd Gen Non-Engine/Transmission A/C Freon valve problem
2nd Gen Non-Engine/Transmission Brakes
Heard about this the other day. . to up grade the steering linkage on my 95 4x4. . I should install the linkage off a 99 3500 4x4. . it appears that it has a linkage bar that runs from wheel to wheel,, eliminating the y type setup on the 95. . thus eliminating the flex in the 95 linkage. . Has anybody done this. . if so is it worth the expense... are any of the parts off the 95 the same as the 99. . adj tubes. . tie rod end. . etc... and what about stabilizer mount. . Thanks Tom
