Steering Lubrication
Amsoil Air Filters
The newest guy on the block ( in more ways then 1!)
Okay, what am I missing here... . The maintenance schedule calls for regular lubrication of the "Tie Rod, Tie Rod Ends, and Drag linkage. " The only Zurk fitting I can find is on the front stabilizer bar. There are no fittings on any of the others, or at least if there is, I'm not familiar with how they are lubed. Any suggestions.
By the way, I have the maintenance manuals, but they don't show the lubrication points. :confused:
to do it right
you will need to drill and tap and install your own zerk fittings
Check the archives "dune racer" put together a great how to do instructions...
