There is a bar attached to the frame on the drivers side by a stud w/grease fitting and to the other side at the axle damper bracket. The fitting on the drivers side showes play and probably needs replaced. I looked in the factroy service manual and couldn't find it in the "steering" section. It's probably a no brainer for most of you guys so your help would be appreciated.
