steering pump replacement
Engine/Transmission (1994 - 1998) Pac brake install
You'll have a problem if you don't remove the power steering pump and the vacuum pump as a unit. Meshing the cog gears is essential. It is a good idea to remove the oil pressure sender because it is in the way and often gets broken during the removal process. Have enough power steering fluid on hand to flush the system.
