Steering pump stud and spacer
KDP. Drill and Tap Jig.
91 to 93 grill
I replaced my power steering pump (on the 92) Monday, first replacement after 253K miles. While unbolting it I noticed one of the studs and spacers were missing. This is the stud that goes through the bracket bolted to the block and through the vacuum pump into the power steering pump. Does anyone know the part number for this stud and the part number for the spacer?
Is it possible for you to provide either the engine serial number or truck vin??? I can then check in the Cummins system to see if it is a Cummins or Dodge part.
If you prefer not to post it please e-mail it to me...
-- email address removed --
Mike.
For some reason the vacuum pump does not come up as an option that your engine was built with. Sometimes the older records are a little shaky.
I used the ESN from the '94 that I owned and I believe that stud and spacer that you need are in this illustration....
Have a look....
#7 3911804 Qty Used is (2)
#8 3911806 Qty Used is (2)
Just compare before installing, should be the same. Don't want to see you jam up a thread or something.
Mike.
