I am in the process of replacing a steering shaft on my 1991. 5 automatic transmission Turbo Diesel truck. My research indicates there are two kinds of shafts, Borgeson 940 and 943.
In order to take the rack joint connector off the shaft, there is a spring wrapped around the top shaft that puts tension on the connector I want to remove. How do I keep the tension off the spring to take the connector off? Has anyone done this type of replacement with the spring?
