2nd Gen Non-Engine/Transmission steering stabilizer q.
just install bilsteins all the way around and the only think left is the steering stabilizer. any ideas on whos? shame bilstein doesnt make one.
I feel the same way. I put 4 bilsteins on also and used Rancho's stabilizers from Summit. I had 2 so I put two back on. Steering was tight for a few months but now the "wobble" is back. Here I go again... . throwing parts at the front end.
Good luck,
Dave
its probably that track bar... . go with the 3rd gen conversion... nice kit and the last time u will have to mess with it.
Thanks for the tip. Yep! Been thinking that myself. I'll sure keep it in mind after I give my baby a checkup. Just been too busy to get under her.
Hoping the track bar is just loose and needs tightened since I never re-tightened stuff. The Lukes Link could need tightening. Hope to check this weekend or next at latest.
I haven't decided if I'll use Sold Steel or what method to get new track bar. My Lukes link does rub on the diff cover so I may need to grind it a little. Maybe that caused it to loosen up. I'll post my results.
Dave
