Going around turns and slow corners, my steering wheel bounces a bit like it does when you try to turn in 4wd. It's not nearly as severe as that, but the same sensation. It's not bad to the point I'm afraid to drive it, but I think it's something that's gonna get worse. I know the truck isn't in 4wd, I can hear it pop out and I can spin rear tires only on gravel.
Crawled unnderneath and everything looks normal. Nothing out of place or bent. Jacked front end up and couldn't find any wiggle like it's the ball joints or something like that. I've never diagnosed ball joints before so I don't know if I did it correctly. Jacked truck up and wiggled tires top to bottom and got nothing.
Front diff fluid is OK, both oil level and change interval.
Power steering fluid is where it should be.
Going around faster curves, anything above 20-25, I can't feel anything. Only when I turn shorter.
Any ideas???
Thanks
Jake
Any ideas???
Thanks
Jake
