Steering wheel align
Looking at the 99 manual, Joe Mc is correct, loosen the clamps on the sleeve on the drag link, the rod which goes from the steering gear pitman arm to the tie rod, and turn the sleeve until the steering wheel is centered. The thread on one end of the sleeve is left hand and the other end is right hand thread so turning one direction will shorten the drag link and the turning the other will lenghten the drag link. If the steering wheel is off to the right you would lenghten the drag link, off to the left you would shorten. Book says do not loosen or remove the alignment bar which keeps the clamps on the sleeve lined up just turn the sleeve and let the clamps turn on the sleeve. Adjusting the rod will not affect the alignment but the new track bar is not exactly the same as the old one or this change would not have occured. I doubt that this small difference would be a problem. bg
