2nd Gen Non-Engine/Transmission Steering wheel Lock positions?
2nd Gen Non-Engine/Transmission Spare power jack - not working...
Engine/Transmission (1998.5 - 2002) Need NV4500 help quickly!!!!!!
I just bought a 2001 2500 when I take the key out of the ignition the steering wheel does not always lock in position... the dealer says it will only lock in 4 spots. . is this true or should the wheel lock right where it is when you remove the key??
I don't have to turn the wheel very much in my 96 to get it to lock. I'll try to determine how many degrees tomorrow.
Paul
My wheel has to turn about plus or minus 45° for it to lock. (Yesterday, I thought it was less but after trying it it's about 45°) So that would be about 4 lock positions. It really doesn't matter though if it locks as I've seen first hand how the column goes together and its only an aluminum casting with a plastic (yup you guessed it - I said plastic) pin. Don't ask how I know as I don't need any hate mail on the lousy steering shafts. :rolleyes:
Thanks VSS... I got the truck back today. . and everything is perfect!! By the way what part of the Brass City? I live over by Blackies in Cheshire
Actually I'm from Naugatuck. I used to spend a lot of time in your end of Cheshire - past job at VDO in the industrial park. Now I work in Watertown (making steering components).
