I had an adjustment done at the dealer this morninng, and now my steering wheel is rotated a few degrees to the left when driving straight.
I did a search and found that I need to use the Drag Link Adjuster Tube to straighten out the steering wheel. According to the post I read, I need to loosen the adjuster tube and rotate it until the steering wheel is centered.
My two questions are... .
Is it as easy as it sounds ??
And, can it move anything else out of spec, causing me any other problems by messing with this adjuster tube ??
TIA
Jeff
TIA
Jeff
