mwilson
I hate to start another "Steering" thread but do not see a similar issue when I searched it out.
My truck will not return the steering wheel to center by itself. It will come back within a half a turn but that is it. It started handling crappy last summer and now after Ball Joints, Knuckle Joints, Alignment, New Tires, New Inner RH Tie Rod End and Steering Damper it is still having days when it wanders. I can't remember the returning to center issue last year so may be new. I have removed the tie-rod ends and worked the knuckles to make sure that the new parts are not binding and both sides move smooth as silk throughout the range of travel. The track bar bushings appear fine and that doesn't really explain the good day, bad day steering of the truck.
I am thinking steering shaft or steering box. What do you guys think?? I will buy whatever it needs and so far it certainly has needed all that I bought. I know that these are good trucks and once you get a handle on the steering issues it's all good, but what a PIA. I have a worn out Cadillac that I commute with showing 245,000 miles on the clock that handles better than this truck did brand spanking new. Come on Dodge, get this stuff figured out for crying out loud.
