Hi Gang; Yesterday I replaced my leaking steering box with a PSC SG-841-M. it was a relativly easy change thanks to having a new pitman arm. (broke the tool trying to remove the old one). As careful as I was the steering wheel is off by a little bit. With the wheels strait ahead the wheel is almost 90degrees off to the right. I tried to reposition the pitman arm, but as you know it goes on in 4 positions due to the shaft segments of 90 degrees.
by repositioning it 90 degrees, it is off to the other side. Any ideas????? Due to the flat on the coupler, the shaft only goes on 1 way. :{
