My steering is stick/bind when driving down the road. have have to minor correct for large crowned roads where I live and drive for a short distance in a straight line without moving the wheel and try to correct and it doesnt want to turn back right. if i feel the bind i can turn left a little and then go back right and its gone. i didnt start noticing this problem until i changed wheels and tires. went from 16x6. 5 with 265's to 17x8 3rd gens with 295's it has the lower column bushing fix, borgenson shaft, dss, adjustable 3rd gen track bar, new gear box and screen was checked in ps pump. i also drilled out the fitting in the back of the pump 2 sizes up. the pump fluid has been changed 2 x's to synthetic. the pump does growl a little when turning fast to the left at the certian spot where it sticks and does it at the same clock position of the wheel when turning left. ex: every time u pass 1 o clock while still turning left. all parts were installed before the prob arrived. i have noticed it does get worse the warmer the engine is. when i changed the gearbox, i lost my steering return. the guy i got the pump from said its characteristic of the pump, being super tight. and wondering if its not the box causing the stick/bind. also checked, not foaming of the fluid in the ps pump when running. any help will be appreciated.
