Hello all,
Well, for the last few days I've been trying to address a steering issue with 1997 2500 (82K miles) my truck. Believe it or not, its not the common wandering problem, its a lack of returning to center after a turn.
Here is what is going on. The steering is tight (not in terms of slop), but in terms of the amount of effort needed to turn the wheel. After making a mild turn, the wheel will almost come back to center on its own. However, try to tight turn and you have to help it back to center.
So far here is whats been done to hopefully correct the issue- with marginal results:
1. The truck has been put in the air and the box, links and track bar were checked- all good and tight. However, the ball joints were really tight. Took a lot of effort to cycle the steering (pushing/pulling on the wheels) right to left with the truck in the are and the column unlocked. My friend is a mechanic and says he's never seen a set so tight. While doesn't think its the problem, he says anything can happen.
2. Caster was adjusted and it helped somewhat, but not totally.
3. The over center adjustment screw on the box was backed off about 3/4 of turn, which really didn't do anything.
What is the other steering box adjust (the one involving the preload bearing) used for? I have a set of new ball joints for the truck and I may just throw them in and see if that fixes the problem. I'm also starting to wonder about the PS pump. Maybe its not pumping enough. Any way to tell?
Any help here guys/gals would be great.
Thanks,
Ryan
Thanks,
Ryan
