Stereo
Pusher Pump Help Needed Fast!
EGT location for towing
I have made my truck fast, now I want to make it sound good.
I want to put a moderately priced system in my 95' Reg cab.
Going to go with a Sony M670 head unit, other than that I'm open to suggestions.
What size subs are yall running? What amps? What componets?
Was going to try and find some Focal polykevlars affordable.
Can I fit 6. 5" in the doors and where to mount the tweets.
I have the Infinity system now, anybody wanna buy it?
If yall have pics of your systems I would love to see them (showoff time):)
As usual you guys are the best.
Later you RATTLIN dudes.
MDW, check the sig for details. Got most of it from http://www.crutchfield.com. They can tell you exactly what will fit your door panels. I put Dynamat on the rear wall and doors while I had it taken apart. Really helps cut down the road noise (but can still hear the Cummins!!). Amp is under passenger seat, CD changer under drivers seat. Have fun!!
6. 5's will fit in the doors. You need to make a reducer plate to fit the 6x9 hole.
I had two Rockford Power 12's running off of half of a Rockford Power 650 in a '97 standard cab. It sounded better than the Power 15's I have in my qaud cab now.
