2nd Gen Non-Engine/Transmission sterring box needed
Engine/Transmission (1994 - 1998) Do I have a Low Fueling Problem
Engine/Transmission (1994 - 1998) TST #12 Smoke?
Where can I find a rebuilt or new box? Mine is sloopy and leaking. Also can you get replacement rubber joints for the 4 rods in the 4x4 front end? Mine are falling apart.
I sell them, send me a PM.
Try energy suspension or warn for replacement upper and lower trailing hardware/bushings you discussed. Have you tried to tighten the pinion and then the overcenter adjustment? This with the DSS (Darins steering stabilzer) will do wonders often and save you $$$.
If you are fighting the death wobble or wander, find a good alignment shop and take them the "brent" specs that are floating around. The 94-97's often need the Astro/Ingall's etc. upper ball joint caster /camber sleeves (eccentrics) that allow for more caster than the eccentrics on the lower trailing arms will allow even when maxed out. .
Good luck
Andy
