I'm open to all comments on this subject but I'm debating whether or not to buy a new truck. Here are what I'm considering pros and cons to buying a new truck:
con - I have the pace system installed on my '02 and love it
con - Just put new E rated tires on it
con - nearly paid off
con - have kick *** stereo system installed
con - '02 last of the body style (very intimidating presence on the road)
con - only has 88,000 miles on it
pro - since lifting, I have a had front driveshaft vibration. So, do you sacrifice driveability to eliminate the vibration or keep caster adjusted positive to maintain excellent driveability? I am currently driving without the ront driveshaft.
pro - cruise works... sometimes
pro - had tranfer case replaced twice under warranty but still leaks (where halves bolt together) Probably needs to be rebuilt or replaced again
pro - now I am seeing a discoloration in transmission fluid where it slowly leaks from quick disconnect coupling near the cooler. An indication that the transmission is about to go I am assuming.
pro - since the truck is nearly paid off, I have positive "equity" in the truck for a good trade-in value
pro - I get a new truck!!! (which I'm sick of automatics and I would get a new 6 speed manual if I got one)
After typing all of this, I think I may have answered my own question.
I would probably put the stock springs back on for the trade-in purposes. I know a lot of you guys out there wouldn't give up on your old truck but with the drivetrain problems I've had and may be about to have, I think I'm ready to give up and buy a new truck.
I invite your comments. Thanks.
Erik
Erik
