Sticking Go Pedal !!! OUCH
Edge Juice HOT Version, do it or not?
Stage 3 CP3... Who's got .. I got questions
I have a problem with the GO pedal sticking WOT... . has ruined several sets of undergarments... and needs a fix. Been to the ***** Dealer 3 times and no solution... any ideas? Usually happens with I pass someone WOT and then have to let off... and nothing happens.
Are you sure it is actually "sticking", or just hanging high on the RPM's for a few seconds when you let off? The CR engines seem to do this for whatever reason, some say it is bleeding off rail pressure that way.
If the injectors are sticking open from debris it will act the same way. How much black smoke are you getting WOT.
are you 100% sure the floor mats [if you have installed some] are not hanging up on the throttle pedal? i have read of a few who have had that happen. .
and if poop does happen, don't be afraid to throw it into neutral [engine will not be harmed at all. governor will catch it]
