The door between my garage and home sticks all the time. It is the vinyl gasket/seal on the side where the knob/latch is that makes it stick. The door is metal and painted. It's not the fit of the door that is a problem, but rather the vinyl weather seal that wants to stick to the paint. Rubbing a bit of WD40 on the edge of the door makes it open & close like a charm but I suspect that by doing this I've made the situation worse in that the paint on the door edge gets stickier once the WD40 soaks into the paint surface. This solution only lasts a day or so and then it is stickier than before. My 5yr old has to throw her whole weight against it to get it to open.
Any suggestions on what to put on it that will last and not soften the paint like the WD40 does?
-Deon
-Deon
