Stihl TS 460 question
IR tube heaters
Discarded Commercial Coffee Makers - Put To Good Use!
Just checking if anybody out there knows the turn settings for the carb on the TS 460. I know the L setting is one turn from seated but can not find the turns from seating for the LA screw.
Thanks
LA adjustment
There is no true start setting for LA. This is just an idle screw which just cracks throttle plate for idle. It should be set so the butterfly of the carb is not totally shut in the venturi of the carb. If adjusted too much in once running just turn out until idles normal then you may adjust and tune low speed adjustment screw that you preset to 1 turn.
